2" spacers and 2" lift coils? | Ford Explorer Forums
xmodster3o3
Ontario, Ca, USA
91 XL
:us: I got a 91 2wd explorer, can I fit some 2" spacers up front along with some 2" coil springs, with everthing else stock?
Also wil doing this mess up the alignment and make it impossible to get right again?
What is the max amount of lift the stock setup can do up front? :us:
If you get drop brackets, you'll be fine. With a total of 4" susp. lift up front and no drop brackets...you'll have alignment problems. I have the new shims in mine with the 2" coils only and I don't think it'd align right with another 1" of lift (w/o drop brackets).
Nope. 2" is the max you can go without drop brackets, otherwise = + camber, horrible handling, and wear out tires faster then you can pay for them.
