Steroid King
- June 13, 2016
- 2003 Ford Explorer V8 RWD
Hi guys. I have a 2003 Ford Explorer 4.6L V8 RWD Eddie Bauer with just over 104,000 miles on it. I recently had a transmission cooler installed, and it is a fin & tube type cooler that was installed downstream of the radiator. I have a Scangage installed through my OBDII port and have it set up to monitor water temperature and cylinder head temperature. My recollection, in the past, before having installed the cooler it rarely ever got above 180 degrees Fahrenheit, even with the A/C at full blast.. Now, with the cooler installed, if it is colder outside, around 65 degrees or below, it generally stays below 180, but in the warmer summer months, particularly above 80 degrees, both these gauges go above 200 degrees if I leave the A/C at full blast, maybe even 210. Sometimes I worry about it and switch off the A/C or even turn on the heater to displace engine heat, which is kind of a bummer and uncomfortable in these hotter temperatures.
Am I being paranoid ? Is my Explorer running at a safe or unsafe range for water temp and cylinder head temp to run at when leaving A/C on full blast ? Could the tranny cooler be choking airflow from the radiator that badly ?
By the way, I just had the antifreeze changed and it still pushes past 200 degrees with full A/C in hot ambient temps, albeit a bit more slowly than before if I recall correctly.
