Cobra Jet
- April 11, 2006
- Southern, NJ
- 2004 XLS
I'm converting over a 2000 Ford Explorer 5.0 V8 to be used with an earlier EFI Ford Distributor for another vehicle application.
Can someone please tell me what type of cam sensor gear was used on the 2000 Explorer V8's (I'm asking about the metal composition of the gear)?
Also, how hard is it to remove the cam sensor timing sprocket from the crank?
The engine is on an engine stand and is currently stripped down so that just the heads, timing cover, timing sprocket, harmonic balancer and crank pulley just remain on it, as I am in the middle of an engine build up.
I will be using a 1986-1995 Mustang 5.0 timing cover, EFI distributor and complete 5.0 EFI setup on this engine.
Thanks for any help!
