2000 parking brake adjustment | Ford Explorer Forums
brian_2000
MA
2000 XLT
My sister's 2000 Explorer failed inspection because the parking brake needs adjustment. Can anyone tell me how to adjust this?
Is it disc or drum?
And man that is some strict inspections you have.
Missouri is quite possibly going to do away with vehicle inspections.
I'm hoping they do because it is a rip off.
I don't know how they regulate it in MA but here you can't trust most of the places that do motor vehicle inspections in Missouri.
When the state allows Midas, Car-X, Firestone & the like to inspect vehicles they lie to people telling them you need this or that to pass when realy you don't.
It adjust just like a old Drum brake. You pop off the cap on the back and adjust with a flat head ;)
Stic-o is right. There is also no self adjusting mechanisam at all so you don't need to move a lever to get the adjuster to turn. If you jack up the wheel just turn the adjuster until you get some drag and then back it off a little.
The parking brake on all of the 95+ 2nd gen Explorers suck big time. They barely hold on a slight hill, they will not on a steep incline. Yes adjust them until they just barely drag with the wheel off of the ground. Good luck,
Dan Whitaker said:
Is it disc or drum?
It has 4 wheel discs.
Yes, living in MA sucks!
It is just a screw adjustment? I'll have to have her bring it over so I can take a look. Thanks for your help
If you are lucky there will be some brake material left.
1-1/2 years ago when I put rear brakes on my '97 Mountaineer there was not any brake material left.
The e-barke set up is poor. What it is is a mini drum brake inside the inner part of the rotor itself.
When you pull the rubber plug, there is a dial inside. Use a flat head screw driver to spin the dial.
Look like this on the inside
i just failed in Nc for the same thing, its easy to adjust it. (just forgot to reset it when i did my brakes)
