Exploder321
- December 7, 2008
- Norfolk, VA
- 2001 Explorer Eddie Bauer
The saga continues... driving home from a day trip and the car started running horribly, had to leave the OD off doing 55 on the highway to get it to run smoothly. Similar problem prior to was plug wires that had melted, so I put in a new set. Ran better, still bad though. Likely culprit was the MAF sensor, replaced it, still have problems; replaced the TPS for good measure. Checked vacuum (see my previous thread on vacuum problems), found cracks in the grey line going to the dash, as well as a problem with the EGR valve diaphragm. Fixed the leaky thin plastic line and replaced the EGR, thinking the EGR solenoid may be flakey put in a new one (all parts Standard, from O'Reilly). I did check the voltage output of the DPFE for the EGR, it was good. Still getting better, now it throws a code for the Evap circuit - so I got a new purge valve to replace the original. Evap code clears and now the P0174 shows up. Put in a new O2 Sensor in the left side, no change - still running rough, poor power, jerky throttle response. So, I don't have a problem with 'throwing parts' at this as most of the components are 20+ years old. Anyway, now I'm off the check the fuel pressure - replaced the fuel pump and filter a few years ago, I doubt its that. Another thread said to check the vacuum line to the power brake booster. Going to check that next also, as well as spraying carb cleaner and listening for idle changes. I am running out of ideas... will report back on what I found.
