engtech
- October 11, 2011
- 2002 Explorer
There have been several threads on this topic, 5r55w transmission with the shift flare issues (p0775 solenoid b) error code. I replaced the solenoid pack/filter and returned the fluid as suggested by another thread on this site. The car ran fine upon road test and the error code p0775 disappeared.
However, when I parked the car, re-flushed the fluid a second time, upon returning the fluid the transmission does not shift into gear? With the engine running, the shifter moves, but no gear engages? Checked the fuses, every seems ok. I even took the pan off and tried putting the old solenoid pack back on, no luck. Also, there are no OBDII error codes at this point?
Any suggestions at this point to get the Explorer to shift would be appreciated...thanks.
