samste
- January 18, 2020
- 2002 ltd 4.6
I thought i would post some photos of my build in progress it may help others or give some ideas the kitchen sink has 2 x 20litre containers inside 1 for water and the other for waste water, using a usb water pump tap and salad bowl drilled out with drain fitted.
35 litre 12v fridge freezer. they both can be moved around to suit how i want the setup to be.
The bed boards im cutting to fit side by side and lenth to cut so it will fit behind back seat when stored away and seat is up. also will cover the boards with a 4mm hard sponge carpet so not to scratch sink and fridge and give it grip as well.
the two piece board setup makes it easy for 1 person or 2 person camping and making it sit on the back seat flat and on the fridge and sink makes more head room.
Going to fit a storage bubble on roof for camping stuff.
more detail as i go along as planning also to add additional storage on sides, back seat, roof cargo net and water filter to sink and stuff
