smpic1234
- August 5, 2024
- kingman,az
- 2006 ford explorer XLT
I had a tranny flush less than 3000 miles ago. Just recently noticed small amounts of tranny fluid on the garage floor. Took it to the dealer and they explained their mechanic put too much fluid in the tranny and they drained it to the right level and said wait a week and see if it stops. Well, it hasn't stopped. 2006 ford explorer xlt 4wd 4.0 V6, had tranny replaced 40000 ago. I had no shifting problems or anything like I experienced with the original transmission. The mechanic that did the work charged me for 16qts, and the tranny holds 13qts. 3 quart overfill. Did not notice any leakage until about a month ago, the question I have is: Could this overfill have damaged any of the gaskets that hold the fluid? The dealer says in order to find the leak they have to drop the tranny, about $1200-$1500. Then fix whatever is wrong. Shouldn't they be doing this for free. Everything I read mentions that the seals and gaskets can be compromised with too much fluid. Any thoughts??
