2007 4.6l condenser leak
dannyisaacs
2007 Ford ExplorerIronman
Just wondering the best place to get a condenser and if it's a pain to replace it? Had it checked today for leaks... They found one and I seen the dye(leak)... They want $730 to repair. I do believe I can do this on my own.
S 2007 Explorer Heat Issue A/C & Heater systems - HVAC 0
2 2007 Ranger ext cab xlt, low heat, a/c just cool, not cold A/C & Heater systems - HVAC 0
B 2007 Ranger. A/C-heater problem. A/C & Heater systems - HVAC 3
M No airflow from the vents of my 2007 Explorer. A/C & Heater systems - HVAC 4
G 2007 cLICKING NOISE BEHIND CENTER DASH VENT A/C & Heater systems - HVAC 3
S Lost Control of HVAC - 2007 Sport Trac Limited V6. A/C & Heater systems - HVAC 3
T No air is coming out of the vents in a 2007 Explorer. A/C & Heater systems - HVAC 7
F 2007 Explorer AC Problem: Yikes A/C & Heater systems - HVAC 0
B 2007 Ford Ranger with a blend door issue. A/C & Heater systems - HVAC 1
T 2007 Ranger Climate Control A/C & Heater systems - HVAC 2
9 Might have lost my condenser to a rock - what else to replace? A/C & Heater systems - HVAC 1
V Connection to Condenser A/C & Heater systems - HVAC 2
D 98 Explorer 5.0L – Replacing Condenser – DIY Project? A/C & Heater systems - HVAC 0
R A/C condenser removal. A/C & Heater systems - HVAC 2
C condenser core replacment? A/C & Heater systems - HVAC 4
J How to inspect a used condenser A/C & Heater systems - HVAC 2
T Blew fitting o-ring on low side of condenser ? A/C & Heater systems - HVAC 3
F15E_WSO 2002 Condenser & Drier R&R---need some words please A/C & Heater systems - HVAC 0
4 Replacing my Accumulator and Condenser, Need help. A/C & Heater systems - HVAC 1
F Universal condenser. A/C & Heater systems - HVAC 1
S Need a new Condenser, anything else? A/C & Heater systems - HVAC 5
P Replace Condenser? A/C & Heater systems - HVAC 0
F A/C condenser A/C & Heater systems - HVAC 4
R 1996 Exploder 5.0 condenser connection? pics? A/C & Heater systems - HVAC 2
9 A/C Condenser ? A/C & Heater systems - HVAC 18
S 1994 Explorer XLT AC leak... A/C & Heater systems - HVAC 2
D Phantom R134 leak A/C & Heater systems - HVAC 1
R coolant leak A/C & Heater systems - HVAC 2
J 2002 Exp LTD- A/C leak A/C & Heater systems - HVAC 0
blueka Got a little leak... A/C & Heater systems - HVAC 17
R 2006 Ranger Evaporator Leak A/C & Heater systems - HVAC 1
P Ghost A/c Leak on '96 Explorer 4.0 A/C & Heater systems - HVAC 0
R Vacuum Leak or Blend Door or Both A/C & Heater systems - HVAC 2
I freon leak 2002 explorer A/C & Heater systems - HVAC 0
C Common A/c leak spots? A/C & Heater systems - HVAC 2
P It's been three weeks and I already found a leak.....Any clues????? A/C & Heater systems - HVAC 0
F easy A/c leak check??? A/C & Heater systems - HVAC 0
A 98 Mountaineer with an A/C seal leak. A/C & Heater systems - HVAC 2
D A/C leak in the low side line A/C & Heater systems - HVAC 1
D 97 Sport Coolant leak A/C & Heater systems - HVAC 0
D Coolant leak. A/C & Heater systems - HVAC 1
I Vacuum leak is causing max A/C problem. A/C & Heater systems - HVAC 1
Z 94 Explorer A/C leak A/C & Heater systems - HVAC 4
M AC freon leak behind the dashboard. A/C & Heater systems - HVAC 1
C A/C Lower Pressure Valve: Possible Leak (?) A/C & Heater systems - HVAC 1
G Where's the leak? A/C & Heater systems - HVAC 18
R weird leak A/C & Heater systems - HVAC 11
G How to find leak? A/C & Heater systems - HVAC 12
M A/C leak? A/C & Heater systems - HVAC 9
Similar threads
