jmr061
- August 24, 2014
- Wisconsin
- 16 Exp Sport
Those 2016 owners that have the 3.5L Ecoboost may or may not be aware of the ESE system in the vehicle: ESE - 3.5L EcoBoost
ESE is an audio system feature that enhances certain engine tones typically induced under wide open throttle or heavy part-throttle conditions. The system uses a DACMC (contained within the ACM) and the audio system speakers.
The DACMC determines the engine tone to enhance based upon engine rotation speed data, engine torque data, and accelerator pedal position data from the PCM. The data from the PCM is processed and converted into an analog audio signal, transmitted to the DACMC internal tone generator, and output by the ACM to audio DSP module as fluctuating AC voltage. The audio DSP module sends the signal to the LHF and RHF door midwoofer speakers as fluctuating AC voltage.
Basically it pumps fake engine noise through the stereo system.
On the F150 this can be shut off with IDS (dealer programming) but I looked and the same is not true of the 16 Explorer. I am going to look into this and see if it can be manually shut off by programming.
Do you like or dislike the noise? I should be getting a Sport shortly and I plan on turning it off.
