2016 Explorer rear a/c | Ford Explorer Forums - Serious Explorations
Redpaint
Liberty
2016 Explorer Limited
My fan blower does not seam to work with my a/c and heater rear controls. Also do not know how to operate from front panel for rear. Any suggestions?
Welcome to the Forum. :wave:
If you have the Owner's Manual, that would be a good place to start reading about how to operate the rear HVAC unit from the front controls. Perhaps your first issue is linked to that.
It might have a rear control lock out on your front control center.
Thanks ….I will look again at the manuel. I am “assuming” it does have a rear a/c because it does have roof vents and controls on the console facing rear seats . Thank you again….when all else fail, check manuel then go to dealer. Thanks again!
I have the same year and model.
You can actually control the rear heat and AC with the touch screen.
Its rather hidden, but will show up on the bottom right of the screen.
Can even turn it off or on.
It only stays on screen so many seconds then goes away.
I discovered it eventually, took about a year to find it. Lol
Thanks! Really feel like a DA! Never ride back seat but grandkids do. At some point I “thought” it was working but oh well….got it now! Thanks again!
We only had this car for 5 years! Go figure. Thanks !
Glad to help, I am a aviator, always finding a screen to punch on.
I will crank up the rear heat this time of year, helps the back of the bus.
Usually just myself.
