2017 Explorer Liftgate "Explorer" Chrome Trim Removal | Ford Explorer - Ford Ranger Forums - Serious Explorations
Oakley1232
Clovis, Ca
2017 Ford Explorer XLT
I have a black Explorer and do not like a lot of chrome so I wanted to vinyl wrap the rear end liftgate "Explorer" chrome trim to black. You'll need enough black vinyl vehicle wrap for this specific trim piece, hair dryer/heat gun, socket wrench, socket extension, size 10 socket,razor blade, and flathead screwdriver/panel trim removal tools.
1) Clean surface of the trim piece.
2) Remove the four bolts which are located directly under the "EXPLORER" near license plate lamps.
3) ****For both ends of piece*** Use flathead screwdriver/panel trim removal tool and lodge in between the chrome trim and main liftgate. Gently pry apart as the plastic clips will detach away from the main liftgate.
4) Remove the rear window washer fluid line and socket for the license plate lamps.
5) Apply wrap once it's fully covered and reattach everything just like when it was taken apart.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
Does the removal affect the rearview camera in any way?
Oakley1232
Clovis, Ca
Thanks..wish I could post pics..if you have Instagram or Facebook I could show you pic of finally product..but no it didn’t affect camera..plugged right back in!
peterk9
Staff member
Moderator
Callsign
VE3
Okay thanks. Just curious. You can post pictures directly from your device with an Elite membership or find a 3rd party hosting site to link to.
Oakley1232
Clovis, Ca
Rumzd
Let me know if this image works
https://imgur.com/gallery/Rumzd
peterk9
Staff member
Moderator
Callsign
VE3
Outdoorfunguy85
San Diego CA
AcuraZine TL/TLX 2015
I'm planning to wrap mine too. Thanks for the idea but I will probably seek some professional help from Gatorwraps.
peterk9
Staff member
Moderator
Callsign
VE3
bigtexan99
2016 Explorer Sport
Here's the part number for the trim FB5Z-13B482-CA (2016 - up) If you search ebay and elsewhere you might find one from a Sport that's already black.
2015- down is EB5Z-13B482-BB
XDM45
Fresno,CA
2017 Explorer Base
Thanks so much for this. Too easy and I would’ve made it more difficult then it really was.
peterk9
Staff member
Moderator
Callsign
VE3
jdgonzalez
Cedar Park, Texas
2017 Explorer Limited
I don't like resurrecting an old post but in this case I think it makes sense.
I want to do the same thing. What brand of wrap did you use? Does it even matter? I'm concerned that the wrap will fade over time (3 years since i'm in a lease).
peterk9
Staff member
Moderator
Callsign
VE3
^^ Welcome to the Forum. :wave:
Oakley1232
Clovis, Ca
Probably too late on reply but it’s still holding up strong and looks the same as once I put it on.
Oakley1232
Clovis, Ca
Looks great sir, what did you end up doing to the chrome door handles?
Our handles were already black...it was just the liftgate and lower door trims that were chrome
peterk9
Staff member
Moderator
Callsign
VE3
FYI, he was last seen here 2 years ago.
Dennis J.A.A.
Location
South/central Wisconsin - Janesville
Orfordville
2017 Explorer Interceptor
peterk9
Staff member
Moderator
Callsign
VE3
Thank you Dennis for posting that video. It will be very helpful for some members. BTW, the member you quoted was last seen here Aug. 3, 2020.
