2017 ordering | Page 13 | Ford Explorer Forums
2017 ordering
Thanks for the link. Mine has not shown up yet. :(
Finally got my window sticker from this site
http://researchmaniacs.com/Ford/TrackFactoryCarOrders.html
You will only get it if your vehicle is 3 to 5 days from being built.
Bartender over here..... My glass is. Getting a little low.....
I've used that site recently to check both my previous 2011 Explorer and my current 2014 MKT and the site says the following;
Please check back later.
The Window Sticker for this vehicle has not yet been released.
This, among other such sites, only works for some and not everyone since Ford made some changes. In other words, it isn't reliable.
Worked for me......... But it will only work for a short time frame if the vehicle is in fords control or a dealers control...... If a dealer has a used car for sell then it will work so you can see the sticker...... Once the car is sold it will no longer work.... New cars it will work till it's sold from the dealers inventory At least that was the way it was explained to me.....
I tried some random VIN's from my dealerships stock on its site. I was able to pull up some. Based on the site explaining the number at the top ( date of build) i was able to see some that were last 2 weeks ago.
BTW, have you looked at your dealer's inventory on its site? My ordered vehicle shows in inventory ( dealer ordered in transit) and i was concerned that someone else would inquire, etc. He told me that is a ford thing which seemed odd.
Yeah your vehicle will show in inventory but it's yours....... I just found out today that may build date of July 25 is changed...... My vehicle is being built as we speak and the dealer has eta of August 1......... Bartender a round for the house......
Insanely jealous. Did you hear from your dealer or did you inquire?
I went by the dealers, which I do a lot....... It's a small town dealer and iam friends with A lot of the employees....... My salesman told me..... I was surprised but from what I hear some of the builds were moved up, might just double check your dealer..... Can't hurt......
Dfred, I reached out. My dealer sent me screen shot if the order screen and it still shows 7/26. :(
l
Well it was a shot.... Pull up a chair..... Bartender........
BUT, this morning my green window sticker is available showing 7/27. :)
First timer here. I'm upgrading from an '08 Escape and jumping into an XLT with 202A in Smoked Quartz and am super stoked. My build date was last week on the 16th and found my window sticker. My dealer has told me I should expect arrival on August 7th. Is that about right for the delay between build and arrival?
I know some folks here have tracked the delivery down to the rail car it's on, but is that only able to be done through the dealer?
Lots of variables there...... Distance from the plant, mode of transportation, load on the carrier....... It could be a lot of different time frames. After it leaves the plant the time it takes is up to the carrier, and in most cases it will be rail and truck..... Which involves two different modes of transport. I live 300 miles from the plant...... A week for me would be great.......
For you people like me waiting on an order..... I copied this from my F150 forum I used when I had my truck..... Good info especially the last part, Etis, after your X is built.... To track your shipment..... I didn't write this but used it while my F150 was being built...... I take no credit for the information contained....
Disclaimer: I am not an expert at any of this. My knowledge comes from staring at COTUS and reading these forums for the past month. There wasn’t even a Holiday Inn Express involved. If edits or updates are needed, let me know.
The 2 pieces of information you need to start tracking your order are the Order# and Dealer Code#. They should be at the top of the paperwork you received from the dealer.
Depending on the type of order you placed (A/Z/X or Retail) and what system your dealer is using, you could have one of 3 different pieces of paperwork (that I know of).
Order Summary:
Order# is top left
Dealer Code is top right, labeled “Sales Code”If the Sales Code has a letter in the middle or at the end, remove it before using in COTUS. Example: Sales Code - F48419H would be a COTUS Dealer Code of F48419
Vehicle Order Confirmation: This is the old system (and the easiest)
Order# top left
Dealer Code top right
DORA (Dealer Order Receipt Acknowledgement):
Order# is after the phrase “BEGIN ORD”
Dealer# is just above that, before dealer name.
If the dealer number has a letter in the middle or at the end, remove it before using in COTUS and place an ‘F’ before it. Example: 48H419 would be a COTUS Dealer Code of F48419
More on DORA: If you are purchasing A/Z/Xplan the dealer HAS to give you the DORA. This shows that not only did your dealer place the order, but they had allotments and Ford has agreed to build the truck. It will also show you your exact A/Z/X price. If you are purchasing retail,some dealers don’t like to share this because it has invoice prices listed.(just go to Edmunds.com and it will show you invoice prices)
DEALER # can also befound at:
US Orders: http://www.fleet.ford.com/fleetdealers/
Canadian Orders: http://www.ford.ca/dealerships/locate/results/
VIN# - This will show up in COTUS and can also be obtained from your dealer, usually within a couple of weeks of ordering. When a VIN is assigned, the dealer should also be able to give you a BUILD WEEK
BUILD DATE: At a minimum this should be available a few weeks before build week. Get this from your dealer or by sending a Private Message (PM) to FordService on this Forum (US Customers). Canadian Orders try FordServiceCA for the PM.
COTUS http://wwwqa.cotus.ford.com/NOTE: At this time COTUS is still in testing and development (beta). It’s not perfect and you will wear out your keyboard/mouse hitting refresh hoping for a change. Sometimes not all of the options you ordered show up in COTUS, relax, it’s normal.
After you have your Order# and Dealer#, you can track your order in COTUS. Sometimes it takes several days for a new order to show up. The ETA is only an estimate, read the footnote.
IN ORDER PROCESSING : This is often referred to as the First Ring of Hell because of the wait. It’s basically Ford’s time to make certain they have the necessary components and herd your order and parts to the starting line. This step could take several weeks, or if a component you ordered isn’t available, maybe longer.
IN PRODUCTION: COTUS will make this change 6-10 days before your build date. A link will show up in COTUS that lets you view your window sticker, the sticker might take a day or two to fill in properly. For a window sticker explanation see: http://www.f150forum.com/f118/answered-window-sticker-explained-291213/
After production COTUS sometimes jumps to DELIVERED for a few days before it moves back to AWAITING SHIPMENT or IN TRANSIT. Don’t freak out,it just does that to boost sales of Xanex.
IN TRANSIT: When it moves to ‘IN TRANSIT’, the ETA will disappear.
If your truck is being shipped by rail, you may be able to track it using this information: http://www.f150forum.com/f118/tracking-thread-vins-build-dates-275592/index87/#post4004703
If your truck is being shipped over the road, you’re flying blind and there’s not any way for you or your dealer to locate it.
DELIVERED: This means check your voice mail and break out the ****tails!!!
ETIS: Electronic Technical Information System
ETIS contains lots of useful information about your truck AFTER it’s built. You’ll need your VIN# to access ETIS. Before your truck is built, the ETIS build date is only a placeholder, something like 30.11.0002. It means nothing so don’t waste time trying to decipher it.
Seems I just read that same post a day or so ago.
COOL ! I saw my sticker. I ordered May 25th. The number at the top of the sticker is 120160719. I hope this means it was built 7/19. My dealer told me yesterday ETA was 7/27 when I told him I had not seen the sticker yet.
It means the invoice was generated on 7/19 to the dealer..... You got a little time.... Pull up a chair...... Bartender......
Unless they have changed the location of the build date, it was on the bottom right of the 2 'Stickers' I have.
its actually in both places I just saw thanks
