CavCop
- August 17, 2022
- Location
- Texas
- Killeen, TX
- 2023 Explorer King Ranch
Anyone know of different/performance parts used on say the ST or Police Interceptor that might not be used/shared on other Explorers?
Like Brakes, Springs, Shock/Strut, Differential Gears, Sway Bars, Engine/Oil Coolers, etc?
I know with the Crown Vic PI and Mercury Marauder they had things like higher power alternator with disengagement clutch for WOT, aluminum drive shafts, 3.55 gears, higher rate front springs, transmission coolers, better front brakes/pads, and a few other things to give them an edge over the base models.
From what I have read, it seems the 18” steel wheels on the Explorer PI are the only real different part. I read the Timberline uses the PI shocks and springs to get some lift, for larger tires on the cast aluminum 18” wheels.
The ST and PI seem close to the same, not sure of spring rates/ride height.
One thing I found interesting is on my RWD Marauder and a Bullitt Mustang, a larger front sway bar seemed to help when upgrading from the factory (the Bullitt rear was small), but for the Explorer it seems the Steeda rear is the main upgrade to stay level in hard turns.
Just trying to see if there are any factory type improvements the ST or PI might have that’s known.
