I need a set of 24 lb injectors for a 99 mountaineer 302.. where can I get these?
I just need some 24 or 30 lb injectors. Which MAF air works.on the explore stuff? As far as plug inAre you changing out the stock 19# for the 24#? If so, are you changing out your MAF to match as well? There are plenty aftermarket injectors available on Summit , Jegs, and the like.
If your looking to add engine performance, this thread will be better suited in the Need for Speed section.
47's are a little to big for my build.well..right now.@410Fortune My stock injectors are #20s and mine is a v6 what gives
Bosch 0280155900 / Ford XL2E-A1C
Unlock Horsepower by replacing your clogged dirty injectors with our professionally 100% rebuilt Flow matched fuel injectors, your engine will run smooth and balanced for maximum performancewww.injectorplanet.com
@mrjody
I have some 47pound injectors m9593g302 ford racing
If your interested
Help me understand this..
So..as we all know our trucks have a fuel pressure that is non adjustable..on the returnless systems(2000 in this case) roughly at 65 psi...
Sooo... if injectors are rated at the standard 39 psi, out trucks are 65psi.. that would make a 24 lb injector almost like a 30 lb injector, is that how this works?
Yeah he's helping me with the ac wiring on my ranger..200$ but I'd confirm with @410Fortune on fitment he's a real pro
Thats ok.. thanks for letting me knowI just looked up these injectors they are 47 lb sorry for my mistake it's been a year since I. Looked until today
Yea my son was like uuuuh dad their #47s I was like DamnThats ok.. thanks for letting me know
