mrd
- June 25, 2005
- Fort Bragg, NC
- 1995 Limited Edition
The halfshaft removal procedure listed in the factory service manual and in Jefe's thread here http://www.explorerforum.com/forums/showthread.php?t=53863&highlight=differential+seal says to simply pry the inboard end of the shaft from the differential housing (the Ford manual actually says to use a CV Joint Puller T86P-3514-A1).
It is my understanding there is a retainer circlip at this end of the shaft. Is there a danger of the circlip breaking off inside of the housing, and causing problems later on when in operation? I found one thread (lost the link) where the poster said to remove the housing cover, remove the case, push the shaft in, and remove the circlip from the inside. This sounds safer but more of a pain. What do ya'll think?
