- June 16, 2003
- Humboldt, KS
- 2000 Mounty
OK
Think of riding a bike up a hill.
If you switch the front, or "crank" sprocket to a smaller one, it takes less effort to pedal your ass up the hill.
The crankshaft pulley will respond in the same manner, however other problems arise. The smaller pulley also turns the accessories at a slower rate.
To correct for this--a smaller water pump, and alternator pulley are needed, because the effective "belt surface speed" is reduced.
This leaves the idler, tensioner, A/C, and Power steering pumps spinning slower, which shouldn't be a problem.
Since the mass of 4 pulleys is being rotated slower--this should increase usable power to crankshaft.
How's that??
How's that??
