I emailed their customer support about our 11 Explorers, it is a little more complicated but still worthwhile.
Thank you for you interest in Champion seat heaters. Our seat heaters are compatible for your second row seats of your vehicle. However, the second row seats in your vehicle present 2 additional install challenges. First, the wiring leads on the harness that connect to the power source may need to be extended from the original 10 feet to reach the power source. However, this is easily remedied by splicing in additional wire length.
Secondly, extra care must be taken when fitting the harness to allow a full range of seat movement without causing damage to the wires. Basically, the second row seats have a range of movement that is not present in the driver’s seat for example. As a result, you will want to ensure that seat has a full range of motion without chafing or pulling the wires as this can lead to defect when excessive stress is placed on the harness. Although it is not complex, it can be time consuming to determine the correct positioning of the harness.
We do install thousands of these same seat heaters for car dealerships and the public and have experienced technicians on staff to answer any further questions you may have. We also have installed many 2nd row seat heaters. Our technicians can also provide technical support to ensure a successful install during our business hours.
Lastly, our seat heaters are currently on special for 2 seat heaters for $99 plus a $15 shipping charge. This special is not available through the web though and orders must be placed via phone or email.
I look forward to answering any further questions you may have.
Best Regards,
Sarah
Champion Seat Systems
A Division of Automotive Concepts of MN
2731 Nevada Ave. N.
New Hope, MN 55427
Phone: 1-877-33-CHAMP or (763) 535-2181
Fax: (763) 231-1733
www.ChampionSeatHeaters.com
www.ac-mn.com
