Jeff213
- March 25, 2015
- Stockton, California
- 98 mounty 5.0 4x4
- Callsign
- KM6BVN
I have been having the oil pressure indicator on the dash go on and off at hot idle when in gear. The check gage light cflickers on and off as the needle on the "oil pressure indicator (switch) bobs up and down, however this really happens only at hot idle after the truck has been under load. I don't know if its an electronic problem or what?
The idle oil pressure in gear is about 40 psi on cold start at higher rpm in closed loop mode and 18 psi when engine is warmed up idling around 700 rpm according to my mechanical oil pressure gauge. This should really not be enough to be kicking the dummy indicator on the dash from what I have read. should I be worried?
I here a very quiet tapping sound, barely audible sometimes unless I am using the stethoscope, or stick my head in the wheel well. I put the stethoscope on the heads and it really isn't any louder. It really doesn't sound like a lifter tick but It might be the start of one? I have a new melling high volume with less than 10k miles on it.
Am I worrying too much about an electronic problem? It seems to run alright still, and still sounds pretty good.
Also forgot to mention, new oil pressure switch installed 10kish miles ago too, did not fix problem.
