4.0 SOHC Performance Motor Build | Page 8 | Ford Explorer Forums
Shes alive!!!
Are you ready to see a 12.99 pass?
Shes alive!!!
Yeehaww!!!! I'm ready to see that pass! You need to mount a camera between the headrest on the passenger seat and record an inside run;) Basically just raise the headrest, place camera on top of seat and squish the headrest on the camera to hold it. I've tried it and it works great!
I am thinking of going soon myself to try for a 14.99, but not really looking forward to it. They normally run wed and fri nights, but for Nov they are running at noon on the weekends. The temps and DA are much higher at noon than at 8pm, so my chances of improving from last time are slim.
Post up pics!!!!!!!!
Give me some time to get her washed up. There's a years worth of crud on it sitting in the backyard with no cover.
I forgot how sweet the turbo sound is. ;)
The turbo has to come back off. It's smoking and making a noise. I'm not sure what I did wrong during the rebuild but will find out once it's back apart.
Dang it Jake! I told you those bearings were for something:D
Hope whatever the problem is, it will be a simple fix.
LOL...I thought those were paper weights for the instructions?
The good news is the turbo is fine. I see no damage and everything is right. I'm pretty sure the problem is the oil drain line routing or the pump is starting to go. I'm re-routing and lowering the pump a bit more to make sure there is a gravity forced flow into the pump. STS says you can mount the pump above or level with the turbo but I'm here to tell you that you shouldn't try - you'll have nothing but problems.
Let me know when your going to the track brother!!
Ill be there to cheer you on!
I found out the track I go to is shut down for the winter. The only other track I'd like to go would be in Baytown. (near Houston)
What tracks are in your area? I might have to make a long haul to get any new times.
Just always drive downhill and the pump will be lower than the turbo. You'll also improve your fuel economy. I'm glad to hear it's nothing serious and I'm confident you'll have the problem resolved soon.
LOL
Yes, the only problem I have with mounting the pump any lower is the turbo is already as low as it gets. So what I'm doing is mounting the pump just above the height of the nerf bars. The pumps protection will be the nerf bar. There will be a potential for something flying up from the front right wheel so I'll have to get creative with a protective cover.
The set-up, before I started revising, worked but I wouldn’t say it worked well. I would get oil in the exhaust side once in a blue moon. It wasn't often enough for me to worry. The reason it did, I'm thinking, is because the pump has always been level with the turbo. I experimented with different sized drain lines (sts recommends 3/8 in cases where the pump is level or higher) but nothing was a permanent fix. So this time it'll get fixed right. (mount the pump lower than the turbo and use -12 size drain line) I may also look at returning oil somewhere near the oil pan VS going into the oil cap like I'm doing now.
I have used both Little River Academy and San Antonio Raceway.
Little River is closer but SAR is nicer.
Little River is about 2.5 hours from you and SAR about 3 hours.
Didnt realize you were that far East of here.
I'll look into those tracks. Maybe we can set something up where we can meet at one of the tracks in the next few months.
BTW - It's the pump making the noise. I'll take it apart and see if I got any ARP thread sealer in it. Other than that, I may need another pump.
Place your oil return in the lower steel pan, that's easy to work with. I was planning to add an elbow fitting to do that with a bypass oil filter system.
For your truck, is the STS pump there just for the return of the oil? How does the oil get to the turbo, a line from the pressure fitting? I ask because I may one blue moon or so later, do a turbo for mine. I have a steel line mounted in the back of my block to get oil pressure to the top of the block. So I will have oil pressure at the firewall for the turbo, and another pressure sensor.
Are there many choices for that kind of oil pump? The Mallory pump I have as an emergency oil pump to install, it's obsolete and no information exists for it now.
On the drivers side there is a oil pressure sensor. You'll T off this for your pressure oil feed line to the turbo. The pump is used only to return the oil uphill back above the sump level. The reason I don't like the lower part of the pan for an oil return line is it is below the sump level. You really want to be above the oil level for the retun or you'll backfill the line to the pump and beyond when the engine is off.
There are a few pumps that can be used. The STS version is one and a couple more are:
http://cgi.ebay.com/ebaymotors/Turb...p5197Q2em7QQcategoryZ33742QQitemZ110612911936
http://cgi.ebay.com/ebaymotors/Exa-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/NEW-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I like the middle one.
Thanks for the links, I'll look for those later. So with the noise you have, are you going to be replacing it?
:thumbsup:
This here is GREAT information for anyone wanting to know where to place the return line on Turbo setups! :thumbsup:
Those pumps look awesome. I bet they all perform well but holy hell on the middle one's price. :dunno: Seems a bit high compared to the other two.
Maybe we should have a sticky somewhere with nothing but Turbo Information... Anyone else think so?
The noise I was hearing was probably the pumps worm gears face rubbing on the bottom cover plate. I opened it and It appears I had the worm gears facing backwards. (there are little stamps on the face of the gear that I had facing up; I reversed this and it's working well so far) I also lowered the pump about 3 inches so I'm not sold the worm gears possible being backwards was even the problem. Just thinking about it, I'm not sure it would even matter which way the gears go on because no matter how you flip them, the angle is the same. :dunno:
The pump is "broken in" when new by running it dry for a few minutes. During this break-in period, the pump is pretty noisy. It quites down after awhile. Possible because I flipped the gears, I needed another break-in period?
Yeah, I'll get that second pump. I know it's pricy but it has ball bearings and the 10,000 hr rating is darn good too. I’ll have to see how good it is.
I've got to burn all this old gas up before trying to re-tune. Got about 1/4 tank left.
The Turbowerx Exapump is one of the best turbo oil return pumps you can buy right about now. Good choice in picking one of those for a replacement. They aren't cheap but you get what you pay for.
