4.0 Sohc Rebuild In Progess! Pics | Page 3 | Ford Explorer Forums
Now that the rebuild is all done, what was the total cost?
I'm wondering too. I'd like to know if its worth rebuilding vs buying a low mileage used engine. Mine is rattling really bad now even at idle and will need to come out this spring...if it lasts that long.
Cost of rebuild
Cost of the rebuild:
Machine shop.......................................................$220.00
(Decking Block and heads, valve job, pressure testing)
Rebuild kit (Bearings, rings, full gasket set)................$470.00
Oil pump............................................................. $102.36
Primary timing set.................................................$87.44
Right cassette set.................................................$49.36
Left cassette set..................................................$62.94
Balance shaft guide...............................................$8.83
Balance shaft tensioner..........................................$13.53
Balance shaft chain...............................................$30.60
Head bolts...........................................................$47.36
rod bolts.............................................................$22.92
Rod bolt nuts.......................................................$4.32
oil pump pickup....................................................$49.43
TOTAL...............................................................$1169.09
Extra stuff I had to buy.
I had to buy a new crankshaft and harmonic balancer...
Crankshaft...........................................................$170.00
Harmonic balancer.................................................$136.56
OTC timing tool set( Ebay)......................................$120.00
Water pump..........................................................$76.56
TOTAL.................................................................$1672.21
Good work. I vote this thread to be a sticky.
one more thing... anyone ever get a part number for that plug in the back of the block that covers the lower jackshaft gear? Anyone know if it comes with the RH cassette kit since it has to be removed?
Well I got all parts 5% over cost... Cuz I'm really good friends with the part guys here. How much of a differance was there in price.
need rebiuld torque/specs for 2000 4.0 sohc
That was an awesome build. I own four 4.0 SOHC engines and 3 of them are running and one is out of order.
All my 4.0s are in Rangers ... I had to come over here to actually get some real information on the 4.0 SOHC.
