Maxmax19773
- March 6, 2020
- Location
- Galleria
- Houston tx
- 2002 explorer sport 4.0
Hi . I’m glad to have you on board with this issue. I will replace crank sensor I have now with the old one ( old one in working condition) and we will see what happens. Anything else I can do to narrow down the problem?The ignition timing I believe is what tells the pcm “we are rotating go ahead and apply fuel and spark”
The crank sensor tells the computer the engine is rotating (via starter)
And the cam sensor is used to start firing in the correct time (time the injectors and spark to the camshaft)
This is a very odd issue you are having
You don’t lose spark and you have plenty of fuel pressure even when it stalls …
Very odd. Could be the pcm itself or something in the wiring/ grounds
