zerodevil
- March 24, 2008
- Anchorage, AK
- 2008 White Limited V8
OK, there was a little debate in one of the recent 4.6 upgrade threads, and i volunteered to see about increasing acceleration in the gen 3 X, by extending the shift points up to 6000 rpm. So i began to work with james over at hensonperfromance.
FIRST off, with 3 tunes tested so far, none of the programs have been able to change the 1st-2nd shift from 5200(arpox) rpm to the intended 6000 rpm...we are still working to fix this problem."
SECOND, I believe the only gear worth extending is 2nd...if it can be used to get an extra 4-6 mph out of it(thus getting to 60 before shifting)..it will yield the most benefit.
THIRD, IMO it would not be wise to stay out of the power band for any other gears other than 1st and 2nd. as the 6000 rpm shifts killed my higher Speed acceleration.
MY RESULTS!!! The first program did extend the 2nd gear enough to get to 60 mph...but i did not shoot video of it. Now on the 3rd program i am starting to lose more and more faith with this idea. my 0-60 droped from just about 7 seconds...to almost 8.5 seconds(likely to be fixed if 1st gear can be tuned to shift at 6000 rpm). and like i said previously..high end acceleration suffered from the vroom vroom reving past its powerband...this idea of 6000rpm shifts might do well in a Supercalifragilisticexpealidociouscalifragilisticexpealidociouscharged motor though...where the vehicle would have an altered power band.
use these two videos to compare performance..both tests were conducted at the same location, in similar tempertures.
Before 6000rpm tune(91 octane tune via henson)http://www.youtube.com/watch?v=q2yW8EObXV8
AFTER 6000 rpm tune(93 octane tune via henson)http://www.youtube.com/watch?v=x8nWjv4Ubzc
again, im still working on getting this down to a science, so these are prelim findings.
