freak
- November 17, 2007
- Location
- Northwest Ohio
- Pemberville
- 2000, Explorer XLS
2000 XLS 4.0 OHV M5OD. Purchased new in 2000 with a couple hundred miles on the odometer. If I recall correctly I spent around $24K on it and waited for the dealer to trade for it because I wanted the 5 speed. Just made it to 400,000 miles on Sunday. Original motor and transmission. She's rusty and dirty but I'd drive it anywhere. Just drove it from NW Ohio to Wash DC in August. Always used Mobil1 and usually Wix filters. Certainly have made some repairs over the years: (I'm sure I'm forgetting stuff)
( I've done all the repairs, no one else has touched the car.)
Intake gasket
injector seals
IAC valve
Top radiator hose
Many tires
Many wiper blades
Many brakes, rotors
Several serpentine belts
Lower ball joints twice
Upper A-arms
2 front wheel bearings
Several door latches
Rear wiper motor
All dash lights
Clutch slave cylinder (twice)
Replace clutch with above even though it could have lasted longer
Parking brake shoes
Brake lights
EGR gasket
Pilot bearing ruining M5OD input shaft so replaced both
Gas tank
Filler neck
Several starters
Several O2 sensors
3-4 batteries
3-4 sets of plugs
ignition coil
front differential - 350,000 miles and it was bone dry inside. Never checked it. Rear is full!
rebuilt alternator (new slip ring/brushes/bearings) twice
rear axle seals
Needs:
Valve cover gaskets BAD
Probably tires next year
Lower ball joints again
driver door latch
All dash lights (LED replacements lasted less than 2 years)
Radiator
Love the car. Runs great. Figure at 25K a year I'll be back in 5 years to say I'm at half a million. Pic shows me sitting in front of Hotel Harrington in DC and I'll admit that pic makes the body look better than it actually is.
Using monthly average historical gas prices for Ohio which I found on a government site going back to 2003 (I used 2003 data for 00, 01 and 02) and dividing the mileage evenly over the months and using my average mpg of 19 (which I calculated several times over the years)... I have a grand total of $53796.11 spent on gas.
Intake gasket
injector seals
IAC valve
Top radiator hose
Many tires
Many wiper blades
Many brakes, rotors
Upper A-arms
Rear wiper motor
All dash lights
Parking brake shoes
Brake lights
EGR gasket
Gas tank
Filler neck
Several starters
Several O2 sensors
3-4 batteries
3-4 sets of plugs
ignition coil
rear axle seals
Needs:
driver door latch
Radiator
