Ok, let's see if I can do these updates as well as 410Fortune...
As soon as the truck was in my driveway the neighbors came to see
Everyone got a chance to sit in it an a quick ride around the block.
The first appointment on the to do list was to get the bed lined with linex
the owner of Truck Builders LLC of Lynnwood took charge an made sure I was happy with the lines because the fiberglass bedsides are a bit tricky
These guys always take great care an go above an beyond for me. This is my 3rd time using them and the results are superb.
They are priced right an do high quality work!!
Next appointment was to get the tires balanced to reduce some vibration an road noise.
The guys at Discout tire hopped on it like Nascar. 4 guys all descended on the truck like a pit crew.
They ran 2 tire balancers an were a joy to watch in action.
This is a free service for anyone who is hesitant to get their tires balanced. It made a huge difference an the tires were so much quieter afterwards.
before I show everyone at work an start driving this daily I wanted to address the body mounts. We ran out of time to do them at 410s shop but I have a nice flat driveway an some tools of my own...
You'll notice in a couple of the preview pictures that the cab an the body were ever so slightly off.
The assumption was because of the method used to mount the bedsides, that the truck could use new polyurethane body mounts an a couple washers to line up the body lines.
I removed the drop seats and pulled back the floor mat to gain access to the body mount bolts. I removed the old OEM rubber body mounts an replaced them with Energy Suspension polyurethane kit.
They offer them in black or red. According to the web site they are the same firmness but most go with red because it's easier to see if they fail. It also matches the trans mount an a bunch of other red accents on the truck.
The first attempt was with washers added an it was obvious they weren't necessary. Then I tried it without washers added an it was spot on.
Turns out the old body mounts just needed to be replaced. Now the front an back of the truck lined up perfect an it's nice knowing we have new ones
In the process I discovered one of the OEM bolts was sheared so it needed to be done.
