TekMan05
- July 7, 2007
- Kansas City
- '00 XLT 5.0 V8
Hey I need some advice from those who have cammed their 5.0 Explorers. I am in the process of overhauling my motor see thread here ----> http://www.explorerforum.com/forums/showthread.php?t=304943&page=3 I was going to go with a custom camshaft from Flowtech Inductions http://www.flowtechinduction.com/fordcams.htm . I even got a Beehive spring kit from them with an 1.80'' installed height. Plans for the engine were relatively mild outside valve train modifications. My goals weren't high neither as far as Power build. Just a nice refresh with work to the heads (Port/polish gasket match lower intake, cut the spring pockets for 7/16'' rocker studs, and a mill of .010'' or .018'' for a little more compression, have to double check with the machinist) Since I bought the spring kit I haven't been able to get in contact with FTI. THey just stopped replying to my e-mails so I had to search else where for my camshaft and rockers. I wanted custom but I will go for a specified cam for my application as long as it will run and run reliably. This is a DD truck so streetable is a MUST. I just want a balance of that with sound&performance.
Here's 2 other cams I got specced for today for my application from another manufacturer who I will not name yet to eliminate biased responses.
1). 35-351-8. Duration @.050 218/224 Lift is .512/.512 with a 114 LSA - This cam the tech support said was the best he could provide since I'm reusing factory pistons. Although he also said if I want more sound that they also could provide that same cam with a 112 LSA. $298 including the shipping.
2). 35-512-8 which specs at 206/212 @.050 480/480 114lsa.
This cam has a wide powerband with lots of torque and mid-range power.
It has a smooth but noticeable idle and great economy.
The cam and lifters combo runs $489.76 with free shipping in the U.S.
So if I Was to choose between these two cams , what would be the better fit for my setup? I still need a good set of Rocker's to go with this as well and can the pushrods be re-used in my setup also?
