5r55e main pressure problem | Ford Explorer Forums
cooldrool
medford or
my trans is suffering from low main pressure...im looking at the SUPERIOR shift kit and the SONNAX valve..but SUPERIOR makes one too...is one better than the other?
How low is the line pressure? A shift kit does not boost the pressure. The boost valve is only 5 psi increase.
You can call either one and ask a tech to verify.
ill have to talk to the mechanic to get the #'s on the pressure...ive posted about this twice before but havent gotten any response
There are 2 pressure regulators, the (main pressure regulator and boost valve), which is valves and springs and the EPC solenoid. Line or main pressure can be low from a blown valve body gasket or a bad pump. If line pressure is ok and EPC pressure is low, could be caused by a blown valve body gasket, bad EPC solenoid, or an internal seal leak.
There is more than one thing that can cause low pressure, your mechanic should know this.
my posts "5r55e shift flare" and "5r55e nightmare" explains the origins of all this
