Brett
Moderator Emeritus
- April 21, 1999
- Littleton, CO
- 94 Explorer Sport
I'm hoping that I can get some advice from the members here. I've been pounding my head against a wall for while now on this issue. I've searched nearly every thread, performed all troubleshooting steps according to ATSG and Sonnax manuals.
Here are some details:
1997 Ranger 4.0L w/ 5R55E transmission. I rebuilt a transmission core from a 1998 SOHC explorer. Trans worked fine prior to rebuild, and I went through it from front to back. New torque converter, bushings, frictions, gaskets, seals, o-rings, bands, filter, servos, epc, sonnax updates, rebuilt valve body etc. (This is not the first A4LD/4R55E/5R55E I've build. All the others I've done have worked flawless)
Transmission worked great for first 100-150 miles, then developed a couple odd issues.
1. Transmission will engage but not move when it is cold in reverse and forward all lever positions. It slips in any position forward or reverse - like if the transmission was low on fluid. After warming up for few minutes, the transmission does everything it's supposed to do normally and on test drives it goes through all the gears flawlessly at all speeds - No slipping and very tight.
2. New EPC went bad. Engagements were rough, trans shifted rough (after it was warmed up and would actually move). Tossed up a odd few codes relating to slipping between gears. After the EPC was replaced with another new part, these shifting issues went away. The EPC appeared to have a mechanical failure because it ohm'd out within spec, yet did not seem to actuate correctly when applying 12v to it. I'll call this issue is resolved.
Easy to see how the 2 problems above could be lumped together. Had to troubleshoot EPC issue first.
So the main issue I've been fighting is the low engagement when cold (like it is low on fluid - but it's not) and not moving in any gear position until warmed up.
These are the things I have done so far:
1. Replaced valve body with one from Central Valve Bodies. Same exact issue is there with the low engagement when cold. Shifts great once warmed up. This valve body is completely tested. Bolts all torqued to 88 in/lb.
2. Validated that separator plate was not mis-aligned.
3. Cleaned MAF, IAT and TPS. (suggestion from ATSG manual).
4. Adjusted both intermediate and OD bands.
5. When I built the trans, all of the drums were rebuilt and air tested for proper operation.
I decided to get a reman VB from CVB since sonnax suggests that this issue could be worn TCC and pressure regulator bores.
Could this be an electronic issue with PCM or other sensor?
I'm also going to try to replace the filter with another new filter in odd chance that the new filter is bad and blocking flow some how.
Anything else I can try at this moment before yanking this out and starting over?
Thanks
Brett
Thanks
Brett
