Here's the pdfs:
http://batman.homelinux.com/images/valve_body.pdf <-- this is the full pdf
http://batman.homelinux.com/images/valve_body1.pdf <--pages 1-2
http://batman.homelinux.com/images/valve_body2.pdf <--pages 3-4
http://batman.homelinux.com/images/valve_body3.pdf <--pages 5-6
http://batman.homelinux.com/images/valve_body4.pdf <--pages 7-8
http://batman.homelinux.com/images/valve_body5.pdf <--pages 9-10
I hope someone finds these helpful.
Andy
The HA will indeed work the same as the CA partDoes anyone know if the separator plate/gasket with the part number 1L5Z-7Z490-HA (98/00 4.0L - SOHC - 5R55E) will work on the 01/02 4.0L SOHC? The part number from the TSB (03-22-10) for the 01/02 is listed as 1L5Z-7Z490-CA.
I'm only asking because I need one for my 02 Ranger and I found one locally but its the "HA" part number (it does have the bonded gasket) and they're telling me it will work just fine in place of the "CA" part listed in the TSB. Does anyone know the difference, if any, between the two? Maybe I can I modify it in some way (like drill a hole or make a hole bigger) to make it work?
in your application.
Those 2 letter suffixes are Ford indentifiers for
enginering codes and usually follow the alphabet.
Meaning that HA is a later code and is backward
compatable with CA. (You might have a problem,
however, with replacing a later part code with an
earlier one.)
