red82gt
- September 5, 2006
- Kelowna
- 2022 Explorer ST
Hello, right now I'm fearing the worst with my trans in my 02 XLT 4.6L. The previous owner had the dealership change the filter and fluid at 70,000km. I had to replace the solenoid body and replaced the Valve body gasket as well to cure it from hesitating to go into reverse or back into drive, the shuddering shift, the flashing O/D light, etc... I did this at 124,000km along with replacing the fluids that I could get out of it (about 4 quarts) and the transmission filter. I used the Motorcraft filter and Mercon V fluid bought from the ford dealer. The fluid that came out of it then was in good shape and replacing the solenoid block made it feel like a new vehicle.
Fast forward to a couple weeks ago, 135,000km, the check engine light and the flashing O/D light came on while climbing a hill and the truck would not go into 5th gear. Shut it down and re-started it and the O/D light was gone but the check engine light remained. The flashing O/d Light has come on a couple more times (always after long highway drives in mountainous terrain)but the check engine light is now off. I haven't had the chance to read the codes yet but I took the drain plug out to get a look at the fluid and it is a murky brownish-red and has a burnt smell to it. Not good, especially with only 11,000km since I serviced it. The transmission still shifts excellently except in hilly terrain at highway speeds-I turn the OD off for any hill that the truck might possibly have to downshift to try and avoid this from happening.
I want to flush ALL the fluid out including the converter but I don't know what's involved to do this. Is specialized gear needed to do this?
Also, what is a good code reader to get that can read transmission codes as well?
I'm pretty sure that the OD band has packed it in though.
