- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Okay I am now building a new 8.8 for my Bronco II, horrible timing, but out of my control.
My current ring gear is FUBARED.
I have never been 100% happy with the axle I have under my truck. I bought this axle many years ago, I paid way too much for it and have always suspected it to be bent on the D side slightly. When we setup the 8.8 to be spring over (donor was 97 AWD Explorer) the pinion angle was "eyeballed" and set for the amount of lift I had then. The shock mounts were "eyeballed" by me and never have been correct. I have learned a few things since then.
This 8.8 has served me well, it has been under the truck for many years and seen much abuse, however it is time to go.
The last few days the truck started to make a noise, nice rotating metal on metal noise, gets faster with tires, not with RPM. Getting worse, shake down test = nada, found some other issues and fixed those, but other then that everything looks as it did last time I installed it hahaha
Yesterday with the help of a friend, put the rear tires up in the air, put truck in D and click click click click...ear up to the rear diff confirms my fear. Its the rear diff...............again.
Flashback, 3 +/- years ago. When I (we thanks Brett) installed my bent beams I also installed a front ARB, 4.10 ring and pinions and had the factory L/S rebuilt in the 8.8. Local shop did the work, Wild West off road, good guys.
They went under a couple years ago now.
Lifetime warranty = out the window.
2 years ago, Move to CA, boat in tow. Go 4wheeling with Rangerx, Jefe,and a few other guys from the CA crew at Big bear. I peeled open the rear diff cover in a rock garden. make it home, just a slow drip. replace cover, replace fluid, when I got home there was still 3/4 the fluid in there so I thought nothing of it.
1.5 years ago, move back to CO, boat in tow.
6 months later (last Dec) BAM! Rear end problems. Open it up, find ring gear bolts backed out, about 3/4 of them. One bolt chipped a tooth on the ring gear, just a tad. replace bolts, lock tight, torque wrench. new cover, new fluid. Living on borrowed time. This was the last thing I did before I finally drove my truck with the 5.0L in it.
8.8 ring gear lasted until yesterday.
These are Ford Motor Sports, 4.10 ring and pinion. I believe the events listed above lead to the demise of my gears. That and I suspect my 8.8 may have been bent from day 1. I would like to say that the 5.0L, plus towing, plus 35" tires blew it up, but I believe that day at Big Bear was the beginning of the end
So the plan:
1-Use this as an excuse to add rear ARB locker (already have compressor and front locker)
2-Get new Ford 4.10 ring and pinion
3-Pull rear end from donor 96 AWD explorer.
4-Cut off un needed mounts from 8.8
5-weld on spring over BII perch's and shock mount tabs in a proper location.
6-pay drivetrain shop to install locker and gears
7-install in BII with new bearings seals, parking brake and disc brake shoes.
8- try to afford a SVO style cover with girdle supports for the ARB locker, and to help against rock peeling.
Crappy shock mounts: always getting hung up on these off road anyways:
I have 1 week or less, I am driving a borrowed car now.....a Jeep! NO!!! hahaha
Good news is I get spare axleshafts and brake parts from the junker 8.8, oh and I will be locked F&R finally (Moab! moab! moab!)
So the plan:
