HAHAHAHA you guys crack my ass up.
Bill, no 4.56 because I would have to do this all over again in the front, and I have another project currently (I just wanna friggin drive the damn BII and pre p it for Moab with a cage and finally finish my current suspension (coil buckets, fix rear shock mounts) With the V8 and the 4R70W the 4.10's are great for the 33's and do-able for the 35's (actually 35's = realy good on the highway!, er say on the way to Moab)
I have a 8.8 axle that needs a rebuild anyways (180K miles). I want a rear ARB.
The D44 TTB or SAS is DOWN the road, I plan to mob this setup I have now, its not even finished and I've only had it a couple years
Kirby, you nailed it. Brett would be required for the tooling and other brain to do this rebuild with. He is a little "tied up" currently hahahaha.
I will be really really lucky if I can get his help converting this 8.8 to spring over for the BII.
I will not re-use the 8.8 that is currently in the BII, It was never right from day 1. I have some "contacts" around town, including two buddies who do this for a living, I buy parts, dissasemble 8.8, take it to them, drop it off.
Pick it up 2 days later, BAM done.
I would love to learn gears here, I would love to go full width, I would love to put on 4 piston Brembo calipers and slotted rotors, truss the 8.8, and do a 4 link, but now is not the time. Snow is coming, I have 3 trucks currently. none of them driving
I cannot bring myself to just simply replace the 4.10 thats in there with another because I believe the 8.8 is bent, fixing the shock mounts is on the list for Moab 06 anyways, and the trucks been limited off road a bit due to lack or rear locker (also on the Moab 06 list
Here is the plan:
remove 8.8 from explorer (sitting right next to teh BII in the garage, hahaha)
remove all AWD brackets, axplorer spring under mounts and tabs
weld on new perches, setting pinion angle.
have it ready for gear/locker on Monday
The BII will likely get a solid axle, D44 with ARB, trail rig.
A 2wd Ranger project is in the back of my mind.
Nothing has been decided yet! hahaha
