Cali' Explorer
- December 14, 2003
- Sacramento, CA
- '97 XLT 5.0
Ok guys, well, my pretty little X is coming up on its 90K mark. I am looking to do the proper service necessary to keep it running right so I was looking for some suggestions to the following:
1.) Cooling System: The cooling system is supposed to be worked on. As of right now, it appears that the Radiator hoses are all the originals (and are getting mighty worn and soft).
I am planning on going through and replacing all the Radiator (including the small one coming off the Water Pump). Related to this, should I go with stock Motorcraft or Goodyear hoses?
I am also planning on replacing the Thermostat while I have this mess disassembled. I am trying to decide whether I should move down a step on the Thermostat and go to a 180 degree instead of the stock 195 degree. I have heard going too low could cause the engine to stay in open loop and burn up a lot of gas, which I don't necessarily want. This is a basically stock 5.0 as well, so any suggestions here would be greatly appreciated. Along with what brand would be the most reliable to go with for long term.
Also, I was planning on replacing the Coolant Temperature Sensor while I had the mess apart. I know It probably doesn't need it, but its not an excpensive sensor and I figure while its apart, I should do it. Anything special I need to know about replacing this?
Last thing on the Cooling System, what anti-freeze should I go with? I normally just run the Green Prestone with a 50/50 mix. Being in Sacramento, temperatures rarely get below 30 degrees F but regularly go above 100 in the summer, so I want to go with the best I can until the next time I change it.
2.) Differential Fluid: To my knowledge, the fluid has never been changed. I was thinking of going with some Synthetic Gear Fluid (Royal Purple) and was looking for recommendations on what weight would be the best. I have 4 Quarts of 75w90 Royal purple that I have left over from another project. A couple of people have said that would be ok for the Front Diff, but not the rear. I just don't want to risk damaging something, so what fluid would you recommend for Front and Rear?
3.) Transmission & T-Case: Both the Transmission and T-Case were serviced about 5 or 6K ago. The Transmission got a regular pan drop with a new filter and gasket and the T-Case got a drop and refill. Besides this one service, I don't know if the Transmission has ever been serviced before (I bought the X with 60K on it), but I have never had any problems with it thus far. I was contemplating swapping out to Royal Purple Synth ATF (doing it myself of course) with the addition of an Auxillary Tranny Fluid Filter, then after about 6 - 9k doing a pan drop and filter change again, but I wanted some input as that's some expensive fluid and I'd hate to drop $100 or so on fluid that will just end up toasting my tranny. Also, would it be worthwhile to drain the T-Case and put the same Royal Purplse ATF in it (its rated for all places where Mercon is used, such as in the T-Case).
4.) Anything Else: These were the big ticket items for me. I have already changed out the Spark Plugs about 3k ago with Replacement Motorcraft Platinums. I need to change the Plug Wires but right now am debating whether I should get Motorcraft replacements or a set of Taylor Spiro's.
My biggest thing is, I need this X to last me at least another 90K without major problems, so any suggestions would be greatly appreciated =). Thanks.
