93 XLT Dana 44 front axle swap. (I NEED HELP PLEASE). | Ford Explorer - Ford Ranger Forums - Serious Explorations
I have a 93 xlt with the front ttb off, and im getting a danna 44 out of a 78-79 bronco. How much does it need to be shotned, and on what side the passanger or the driver. Im not doing a four link right not im doing the same set up as froader. Is there a complete thread thats shows step by step what i need and what i need do as far as installing it. Thank you so much. :). :D
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...It is late so replies may be few...I can only add that it will be 6" off the passenger side that needs to be cut...
CountryBoy78
Rice Lake, WI
94 Limited 4.0L 4x4
just go full width like LD50 did on his 93..........it looks badass:thumbsup:
rhauf
Ca
91,93,98,&02 Exploders
or cut a little less of if it'll save you from having to use offset rims :)
then again i suppose you want to match the rear.
Tbars4
Moderator Emeritus
Elite In Memoriam
90ranajo
The Little TJ that could
Pattaya, Chonburi
2012 Toyota Fortuner
Callsign
KG7MXH
6" (5.96875" technically) off of the long side will bring it down to Early Bronco width and still be able to use stock shafts. Any more or less and you will have to custom shafts made.
A '78-79 FSB has a long side of 33.90625" and a '71-77 EB has a long side of 27.9375".
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
welcome
DUDER 1
Nomad
94 XLT
Cool ill is real costly to cut an axle, and by the way thanks for the respone from all of you this site is awsome ive had my exploder for years and never knew this site was here.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Dannyboy
Other Make & Models Mod
Moderator Emeritus
43°48′48″N 91°13′59″W
91 4 do'
Best link I know on how to shorten.
http://www.4wheeler.ca/index.php?showtopic=391
Followed up with a great tip by Kirby N. - Don't attach the c-wedge in 6" but instead move it in like 5", this will help when you put on your coils to help with them bowing outward.
I see your in AZ, i've done this before if you're close and want a hand.
fordxranger
Everett, WA
92 Eddie/89 ranger ex cab
Dannyboy: I'm almost positive that the 78-79 d44 hp's have the cast in wedge that has the c and everything as one hollow piece. if he sets the wedge at 5" in he will need a custom shaft. he couldn't use an EB length.
OP: you'll have to use a high nickel rod to weld it back in place once its narrowed if you decide to narrow it. I have a set of flattop knuckles too if you want to run a highsteer, I might put them up for sale. I think I want to just save and get a 60 rather than build my 79 d44, but i'm not too sure yet.
90ranajo
Pattaya, Chonburi
Callsign
KG7MXH
Yes, 78-79 D44 are cast wedges. They can be shortened, but are more complicated and are best left full width. If you truly want the a shorter axle than look at pre '78 D44s from a F100/F150 or a D44 from a '78-79 F250. If you can find a U100 that still has the D44 that will work with no cutting.
crazyflights
St. Joseph, MO
97 1 ton Jeep
Fusion213
Jacksonville, NC
'98 XLT 5.0L
Leave it full width since it's a pain to cut it down. I wish I left my front end full width instead of cutting it down.
DUDER 1
Nomad
94 XLT
Thanks so much for the help so i should go with a early bronco axle, i can use the stock knuckles and spindle off the 79 axle to give it disc brakes, and what is a u100. Thanks so much.
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
Leave it full width. If you cut the axle down it will move the diff towards the center of the truck. This will require you to have more lift and less up travel. Full with and a heavy offset rim would be my vote. Get the easier setup of the suspension and a better scrub radius at the tires.
Stic-o
Elite Movie Star
Lake View Terrace, CA
'91 Navajo '99 X '19 Rngr
Another vote for full width here.:thumbsup: If you run the right backspacing it will not be that much wider then if you were to cut it down. Besides the tires sticking out a bit protects the body a bit.;)
I'm running a 78-79 Bronco Axle by the way.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
If you made a poll, id bet about 95% of the people here would say go fullwidth. And i would be one of them. :D
