spguest
- July 15, 2009
- Bellevue, WA
- '95 Limited
Sorry if I have missed a previous thread which covers this and please do point me it if it exists. Clearly my search missed it.
Due an unforgiving bush the driver's door on our 95 Limited got pushed out of alignment. The manual says to slacken off the nuts and gently pry the door back into position.
Note the lack of a gap between door and fender.
I have encountered two challenges:
1) Getting at the bolts and nuts which hold the hinge to the main body work.
These are the nuts and bolts for the top hinge.
This is the bottom hinge. Note I cannot see or get at the lower rear nut which I assume is behind the door stay device.
The front bolts are also accessed through the now much narrower gap between door and fender.
How do I get at these nuts and bolts?
2) Even though I can reach the top hinge nut and bolt I cannot get a socket to fit on the front bolts top or bottom. When I put a 1/2" open ended wrench on the top nut I still cannot turn it and the nut is beginning to round. Likewise I cannot find a socket AF or metric which I can place on the forward bolts accessed between the door and fender.
What size are these nuts and bolts? Does anyone have a secret on how to make the adjustment to allow the door to move back into place? Do I need to remove the door to do this? The Haynes says I do not but I cannot work out the trick to avoid this.
