96 Explorer XLT Tire Size | Ford Explorer Forums
Baka559
Fresno, CA
1996 Explorer XLT AWD 5.0
Hey guys, I have a 96 Explorer XLT 5.0 and the guy I bought it from had 27" sports put on. I want to know if it will fit 31" all terrains stock. If not would a Front TT and a rear block(both 2") be good and give enough room? Thank you
A 31' should fit fine on there stock without having to do a TT, but you can't do a block on the back for lift since its spring under axle. If you were to put a block it would just lower it.
Ok thanks, for the back, would shackles work on the leafs? Or add a leaf?
