JGood325
- February 1, 2007
- Lancaster, PA
- '97 5.0
Hey guys,
This is my first post here. I'm a BMW guy, but bought this 97 V8 AWD Explorer for a bad weather driver. I love it so far. It has 116k miles and seems to run great.
Anyway, today it started shifting way to high. It does it in every gear. Depending on throttle load, it will shift between 3k and 4k for the 1-2 shift, 2.5-3k for the 2-3 shift, and so on. It won't even go into overdrive unless I take it up to 60mph and then leave off the gas. So it's all the gears, which kind of eliminates solenoids (there is separate solenoids for each gear, right?).
I can even leave off the gas while in 1st gear at 2800 rpm's and it will stay in 1st gear, it won't shift into 2nd until around 3k.
I checked the fluid level, it's in between the cold and warm marks (after an hour drive, with engine running and in park), like it has been since I bought it 6 months ago. Fluid looks clean. There's no check engine light, OD light, or anything unusual like that.
Any idea's? Thanks in advance!
Justin
Justin
