- July 13, 2005
- Location
- NC
- Garner, NC
- 2019 F150
- Callsign
- N1LVN
Got a photo? Would be interested in seeing how it looks, since it is smaller than the OEM lamp.
After I removed the ballast...I can't see how to remove the bulb. There is a single screw with nut in the center of the "hole" which the ballast covered..but the removal of the nut doesn't see to release anything. I'm hesitant about applying pressure to avoid breaking the lens. How do I get to the bulb?
The aren two more nuts on each side hidden behind two large rubber plugs.
For a '97, the molding has to come off, per the Ford shop manual. Drill out 7 rivets (along the length of the molding) and remove one cap-nut on each end of the molding. The lamp and lens then pull out of the molding. I could post a scan of the manual pages for this, but the pictures are absolutely useless!
I was thinking about this, not because my neon brake light isn't working, but because drops of water show up inside the lens after it rains. Just figured that it is only a matter of time before it quits working.
Does anyone know - can the trim be held back down with sheet metal screws? The shop manual says to install 7 new rivets![]()
Thank you for your advice. This fix is not one of Ford's "Better Ideas", as it involves considerable time and effort just to replace a light bulb. I contacted a junk yard in Hackensack and spoke to someone who seemed to feel that in most cases, the ballast dies, not the bulb. So I will replace the ballast tomorrow with a used one for $35 and keep my fingers crossed. The spokesman at the junk yard also reitereated the same proceedure as you to replace the bulb. He said it was a real pain in the ass, but had bulbs in stock too, if I needed one..........Thanks again.
maybe a dumb question, but my Explorer '96 doesn't have a 3rd brakelight
what's that about ?
Probably cause it is burnt out. It's there at the top of the rear hatch window.
Maybe since the Willemspark Explorers have the extra bumper lights, they couldn't have a third-brake light too.
willemspark explorer? i feel a bit like a noob here LOL
I've found another exactly the same Explorer on a site, and it also doesn't seem to have the 3rd stoplight....
weird...
It is the brake light above the back window...referred to as the high mount brake light.
Pooe design by Ford..it is complicated to repair/replace, as you will see in reading other posts.
I got the led's from autozone for about 20 dollars , i also soldered the balllast to neon connecters, as a quick connect, heres is some more pics, thanks for the compliment btwHey Macario, great looking repair. Just did a quick, LOL, repair to my third brake light to pass inspection, but would like to do the LED thing as you did. Where did you get the LED strip, local shop or online? Thanks for the great pics.
Just ordered a 30 LED strip from superbright so I can make a proper repair to my 3rd brake lamp, same price, $12.95 and about $3 to mail it.
