Thank you Jakee. I'm not disagreeing with your setup at all. In fact, I'm going to use your method #2, as I trust in it.
Yes, I tried your second method (albeit I admit I only created one vacuum port on the intake, instead of two as you had done, due to lazyness). The bad oily/gassy smells were gone! Yesss! But, after about 10 minutes of driving, my truck smoked badly. My turbo puked oil all over. I thought I had blown a seal or something. The oil leak appeared to come directly from the turbo, as it was dripping out of it too. If I left it to idle for 5 minutes, it would clear up, but as soon as i would drive in boost, it would smoke again badly. Apparently, oil pressures and crankcase pressure were working against each other... I read numerous articles about this, similar to turbo cars suddenly puking oil due to a clogged air filter... too much vacuum in the wrong places...
But for my own understanding, could you help me understand this a bit more? I'm assuming that the pcv valve you are using is now operating in exactly the OPPOSITE to the way it should in its stock form. (Since the stock one (with a tee'd head) doesn't seem to let air out of the crankcase...it only lets air get drawn in - I tried blowing and sucking on it to determine this. )
So, if this is the case, in your second setup, I'm wondering where is the crankcase is getting its fresh air from? Is it simply relying on the blowby and crankcase pressures, generated from boost and boosted engine operation, to let the smelly stuff out, and not using "fresh" air at all? Are both the valve cover vent and the crankcase route therefore "exits".?
I'm infeering pcv directions from your statement: "The line from the valve cover doesn't really need an ...oil separator ... but the one from the PVC will need this. If not, you'll be blowing oil back in the intake." So the pcv now vents to the pre-turbo intake?
Right now, I had tried a pcv valve on the back of the crankcase (experimenting in both directions), connecting it to a catch can, and finally connecting it to my pre-turbo intake.
Findings from pcv switched both ways, where I always left the front valve cover vent wide open. Both ways I had the same problem: The truck pukes oily watery sludge out the valve cover vent, even at idle. And it stinks so bad, that I open the window every time I get off the highway and hit stop and go traffic. The strangest part is that either way, the rear vent does not EVER emit any visual oily mess, unlike the valve cover vent. This makes me believe that the stock pcv setup is best, since its only seeming drawing air in here. With the pcv positioned either way, and with the valve cover vent left open, there is no oil burning/dripping problem.
I'm really lost here. In the meantime, I will try your EXACT setup, because clearly I can't grasp this whole concept, and see if my woes go away.
