Let's talk boost controllers. I didn't realize that the manual boost controllers are so inexpensive. On the other hand, I found some electronic boost controllers that were way exspinsive. My question is what all is offered with a good electronic boost controller?
For example; The Greddy PROFEC e-01 http://cgi.ebay.com/ebaymotors/GREDDY-PROFEC-e-01-e01-ELECTRONIC-BOOST-CONTROLLER-JDM_W0QQcmdZViewItemQQcategoryZ33742QQihZ019QQitemZ290183427746QQrdZ1QQsspagenameZWDVW
Or
http://cgi.ebay.com/Trust-GReddy-Pr...ryZ43807QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Should I go ahead and plan one of these electronic controllers or just get a manual boost controller?
Here's a little tip I learned. When you need a good line for an angle you plan to cut on some pipe, and only have a cut-off wheel to do the job, mark the pipe as best as you can with a sharpie. Then, fill a bucket with some water; add a little die to it; then dip the pipe in at the angle you need. Pull the pipe out and let dry for a minute, then cut away with your cut off tool.
Actually, my neighbor showed me how to do it. It's something so simple, yet I've never thought about it. I used to get as close as possible and then grind flat.
Robert - How's the tuning coming with the LS?
If you are going to do a boost controller, why don't you keep it simple like the STS style dial boost. A switch,solenoid and a manual boost controller. It is effective and simple. You have the wastegate spring setting and at the flip of a switch you have the amount of boost you determined with the dial. I like mine and have never had a problem with it!
Yes, I've decided to just go with a manual boost controller. Nothing fancy needed for me.
The intercooler and piping up front should be going in this week.
I am running 123,987 Torr! I love boost!
Good luck with that part. I will be adding a FMIC someday(if no one buys the truck first), but I will have to take alot of the front end apart to do that. You have a little more room under the hood than I do though.
It can be done but It's not going to be easy on my ride. I've already noticed that I may have to go with something smaller. No problem cuss a friend already offered to buy the one I have.
I'll try and get some pics soon.
Justin, if I can fit a decent sized FMIC into the front end of my Lincoln LS then I am sure you can fit a good sized one in the front of your X.
The problem isnt fitting the intercooler, it is running the tubing to it. You know how little room there is in the 5.0's engine bay. My intercooler is doing a great job where it is now though![]()
