99 EXPLORER OVER HEAD CONSOLE SOCKET BULBS | Ford Explorer Forums
zorronj
Newark NJ
1999 Limited Edition
Hello
I'm looking for the Over head console socket bulbs, the brand name that I have on mine is STANLEY but I couldn't find it even a generic one
thanks in advance for any reply
EXPLORER 99 MAP SENSOR WIRES PART NUMBER PLEASE
I'm talking about this harness wires on the top of the engine that I have with electrical tape
What exactly is wrong with it? Broken connector, wires exposed?
If its just that section of the wiring, then you can just cut that section out, solder in some new wiring with heat shrink over it, that should be fine. Or you can go to a junkyard nab a pigtail, wiring as far back as needed, cut and put that new one on with solder and heat shrink. Either should work fine as long as that's the only spot of issue on the wires.
it's a big area that's why I want to replace it the whole harness
As said, can cut as much wiring as needed from the junkyard harness. But I'm not sure you'll find that new, let alone do I know the exact name or # for that one. Just my two cents, but junkyard would be quick, easy, and cheap; long as that wiring looks fine, should be okay, just follow yours and cut where it's safe, then copy that for one on a junked X, so that you can directly replace it
That knock sensor harness plug is part of the main engine harness you will have to replace the whole engine harness if you wanna just replace that 1 connector cut and splice imo
If its just on the knock sensor side then pull the intake and replace it
And as always, you've got the links to parts, not as long of a harness as I thought it may be
Thank you, I ordered and waiting to receive it cut it solder with heat shrink tubes
