anarky321
- May 10, 2010
- Jacksonville, NC
- 1998 Explorer Sport
1998 Ford Explorer Sport
situation: a/c compressor cycles on/off rapidly - 2/3 seconds -on and off forever while the a/c is turned on. when a/c is turned off the compressor just freewheels normally.
what i have tested: low pressure cutoff switch - i jumped it and nothing changed, compressor keeps cycling on/off, pressure on the low side was tested with a gauge - about 50-25psi at startup then the pressure grows as the car keeps running, up to 80+psi , voltage at the compressor plug is a steady 13.1x volts while the car is running, this is tested with the voltmeter between the wires with the harness off, voltage at the low pressure cutoff switch is also a steady 13.1x volts, also tested while the plug was taken off, there is continuity between the 2 terminals of the compressor - ~.5 ohms, doing an ohm test from either terminal of the compressor to frame does not give continuity, not sure if that means anything, the WOT relay clicks every time the compressor comes on and off, the A/C 15A fuse is good, i tried switching the WOT relay with the identical one next to it, no difference in operation, i think it was the PCM relay
the a/c does not blow cold air, ever, i have not been able to get the A/C compressor to engage for more than 2 seconds under any conditions, i have NOT tried jumping the A/C compressor directly from the battery and im not even sure how to, is that even necessary given that there's a steady 13.1V on the harness going to it?
edit: where is the high pressure switch located? since the voltage at the compressor is a steady 13.1V doesn't that automatically mean that the low/high pressure switches are not the issue?
