XLTByAccident
- January 11, 2010
- PTown, California
- '92 XLT
I'm finally putting my 1992 A4LD back together and I had to replace the #4 thrust washer to get the proper endplay. The new thrust washer is plastic instead of metal. The transmission shop that I got the washer from said that they can no longer get the metal one and have used plastic thrust washers with no problems. As a modification the ATSG update manual says you can drill a hole in the center support for better lubrication to the #4 thurst washer. I can't tell for sure, but it looks like if I drill at the location specified, I will cross through an internal fluid chamber allowing more fluid to reach the center support thrust washer. Anyone done this modification before? Thoughts or advice one way or the other.
