jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
i know the A4ld is shifted by the solenoid on the side and runs off vac.i have a SC so i need to know how that solenoid works.how does it know when to shift,is it at no vac it shift or a set number of vac it shifts?
this is going to sound alittle crazy but what i really would like to do is remove that solenoid and use an electronic solenoid from a later trans.i then could hook it up to my shift light on my tach so when the light comes on it shifts.anyone know of a electronic solenoid that would fit the bore where the vac controlled one is now?
i dont want to get to crazy with it as the a4 will probably be pulled after summer,but would like to have some control over it till then.ever sense ive done my rebuild on the motor,before sc.it has never shifted on its on at full throttle it just hits rev limiter till you let off or manually shift it.i cant have it bouncing off rev limiter once i put the sc on so need to do something
