Update
The tranny is in. Now it's just matter of all the small stuff. Shifter, starter, dust cover/lower bell housing, bypassing computer, cooling lines, etc.
The adapter consists of a new output shaft and tailshaft housing to mate the stock transfer case to the 700-R4. As for the front end, there is an adapter between the engine and tranny to alow bolting of both. Between the flexplate and torque converter, there is another spacer, kinda like a big washer, to compensate for the space the adapter added and adapt the 4 bolt pattern of the flexplate to the new 3 bolt pattern of the 700-R4 torque converter.
They weren't able to adapt the stock shifter linkage so a B&M floor shifter will be used.
The TV cable is being addressed by Bow Tie Overdrives and they are making a new linkage part to attatch to the throttle body so the tranny will shift properly.
