hehehe the automatic trucks have a plsitci 3 way jumper clip that clips right into the clutch switch harness, you unplug the clutch switch and plug in the jumper.
I have this in my truck.
Also grab the clutch block off plate from the firewall and the kick down cable off the same truck.
Also pay attention to the kick down cable bracket on the A4LD itself, there are many different versions.
Here is how I did mine, oh and I had to go back and put the two shift solenoid wires back into my harness because I stripped them out along with all the other 4.0L stuff I didnt need when I did my 2.9L conversion....
Rebuilt entire wiring harness it was time anyways, I had a few trial and errors from when I did the original harness, added auto tranny wires
donor was a 93 Explorer A4LD, custom built with improvement to valve body, custom converter, etc....
Shift linkage in A4LD was changed out with a shift lever from a 86 Ranger A4LD
Floor shifter from a 84 BII 2wd including BELL CRANK assembly and linkage
Floor shifter block off plate
A4LD tranny wiring harness
93 Explorer A4LD computer, no EGR
Hayden class A motorhome tranny cooler
Rubber tranny cooler lines, high tempature.
I cut the 4 ends off of the feed and return metal tranny cooler lines from the donor Explorer, this allowed me to use a simple flare tool and thread the fittings into the radiator and tranny, yet run rubber tranny cooler lines with hose clamps! Works awesome!
Also the floor shifter from a 84-85 2WD BII and bell crank assembly should work perfect on an Explorer as well, as long as you get the appropriate shift lever in the tranny case and the right kick down cable and bracket......
