ebxploder
- January 14, 2009
- Brunswick Ohio
- 92 Eddie Bauer
Hi everyone! I'm a new member here, and this is my first post to the site. I have a 1992 Eddie Bauer Explorer, 4x4, with the dreaded AL4D automatic transmission. The truck has just shy of 247k on the clock, and the trans was rebuilt @ 130k. It has started to leak trans fluid at an alarming rate. I initially thought it was the pan gasket, and although a couple of the bolts were a little loose (and I only snugged them up a bit), the leak didn't subside. I did notice that the trans leaked alot when put in gear. While lying underneith the truck deciding what to try next, I noticed something hanging out from the passenger side of the trans. It turned out to be the snap ring that holds what I believe to be the OD servo in place. The servo was partially pushed out, and that's where the fluid was coming from. I pushed the servo back in, and cleaned the groove for the snap ring, and reinstalled it, hoping for the best. It has started leaking again for the same reason. I've done lots of Google searches (how I found this site), and found next to nothing about this. Anyone have any ideas as to what may have caused this, or if there is a fix, short of a rebuild or trans swap? I can't tell if the groove for the snap ring is damaged, and I haven't decided whether or not to pull the exhaust to make some room to look. Thanks in advance!
I see I posted this in the wrong catagory...sorry...feel free to move my post, or if someone knows how I can do it, please let me know. Thanks!
