03_LTD
- December 24, 2003
- Indianapolis, IN
- '03 Limited 4X4
I did this tweak yesterday! Before the tweak the voltage reading was .987V, after it was .958V! The idle sure seems to be smoother than before!
99-5.0explorer,
I don't recall which two wires I tested, but all the other combinations I tried were way over a fraction of a volt! Once I got a reading of .9 somthing, I figured I had the right combination! I'm pretty sure it was taken between the two grey wires, and the red lead was probably connected to the grey and red wire. I didn't have to even remove the TPS, just wiggled it till I got a reading as close to .960V as I could and then tightened down the screws. It's a pain the butt on the 03 because the TPS is on the back side of the TB and there's not much room to manuvere. I used an off set phillips screwdriver. I took a couple of the wife's sewing needles and slid them into the back of the connector till they touched the metal, then attached the volt metter using alligator clips. The freed up my hands to adjust the TPS and tighten the screws while making sure the voltage stayed on mark! Good luck!
99-5.0explorer,
