rs2k
- December 29, 2012
- Wichita, KS
- 2014 Ram 1500 Laramie
My explorer leans at least an inch to the driver's side. I just got done swapping the rear springs, tightening the driver's side torsion bar (a lot) and loosening the passenger side torsion bar (not as much) and the truck is still leaning to the left. Any ideas on what else the problem may be? Could a bent sway bar cause the problem? What about a leak in the ARC system? The ARC system seems to work just fine. When I turn it to Off road mode all the shocks raise up about the same amount. When I switch it to normal mode they all lower by about the same amount. When the truck is off and the switch is left in off-road mode the truck slowly lowers back to normal height.
