aldive:
i just found the 37 codes, there are 4 posibilities:
B1996 - Passenger side AirBag Shorted to Battery or Ignition
B1997 - Passenger side AirBag Shorted to Ground
B1998 - Passenger side AirBag Resistance High
B1999 - Passenger side AirBag Resistance Low
*** Deactive AirBags ***
for 1997 - measure resistance between passenger side airbag seat harness C314 (connector) WH/YE wire and ground. is it under 1000 Ohms?? if so, correct short. if not, measure resistance between passenger side airbag seat harness C314 (connector) BN/YE wire and ground. is it under 1000 Ohms?? if so, correct short.
1998 - measure resistance between passenger side airbag seat harness C314 (connector) WH/YE wire and C308 WH/YE wire. is it under 1 Ohm?? if not, correct open. measure resistance between passenger side airbag seat harness C314 (connector) BN/YE wire and C308 BN/YE wire. is it under 1 Ohm?? if not, correct open.
the others are a bit more complicated so a B code would be best if the 1997 or 1998 don't solve the prob.
